Problem when turn-off transmiter >
Old 06-22-2013 | 03:04 PM
Default Problem when turn-off transmiter
My configuration:
Transmiter: Spektrum DX 3S
Reciver: OrangeRx GR300 Spektrum DSM2 3Ch 2.4Ghz Ground Receiver
ESC: HobbyKing Brushless Car ESC 60A w/ Reverse
Motor: HobbyKing X-Car 8.5 Turn Sensored Brushless Motor
I have a problem if I accidentally turn off Tx, car suddenly accelerated.
I have to manually turn off ESC to stop motor. Is there a solution for this, is the problem to Tx, Rx or ESC.
artur72 is offline
Old 06-22-2013 | 03:21 PM
howardcano's Avatar
If you use the Spektrum SR300 receiver, then it will failsafe to the throttle and steering positions present during the binding process. I'd guess that all of the Spektrum receivers do this. (My SR3500 also behaves this way.)
Or you can just make do with what you have. The behavior you describe was normal on the non-computer radios we had many years ago. You just learn to make sure that the transmitter is on whenever the receiver is on.
howardcano is offline
Rebind the radio system with the throttle at neutral. Wherever the radio is when binding is where the failsafe is set.
Dave H is offline
Old 06-23-2013 | 07:09 AM
I solve the problem when I rebind the Rx, Thank you all.
artur72 is offline
Old 06-23-2013 | 10:01 PM
Glad you got it sorted but you should practice powering the vehicle off before the radio. And powering the radio on before the vehicle.
trigger is offline
