DSM2 Module for M8?
Old 06-06-2013 | 08:31 PM
swarf's Avatar
Default DSM2 Module for M8?
There seems to be a lot of dsm2 modules out there especially from HK.
Has anyone found one that works with the M8?
I really like the old brick and the spektrum pro module won't work with LRP speedys
swarf is offline
Old 06-06-2013 | 09:17 PM
nexxus's Avatar
Super Moderator
I used a frequen module when I had an M11 (also fits M8) which seemed to work well but it's not cross compatible with other 2.4ghz gear.
http://www.ebay.com.au/itm/FREQUEN-2...c488d5d&_uhb=1
nexxus is offline
Old 06-06-2013 | 10:43 PM
swarf's Avatar
Looks good. Did you try using it with LRP speedys? I really wanted dsm 2 so I could use the M8 to bind to the orange rx's and control all my cars without spending a heap on additional rx's
swarf is offline
Old 06-06-2013 | 11:17 PM
nexxus's Avatar
Super Moderator
I can't recall using it with an LRP but I think the issue off memory was to do with the Spektrum neutral zone not liking LRP's auto set up. Some Castle esc's do it too until you go into Castle Link and push the neutral zone to the maximum value.
nexxus is offline
Old 06-07-2013 | 09:59 AM
swarf's Avatar
i don't really understand. Can you put it in more noob terms?
swarf is offline
Old 06-08-2013 | 08:59 AM
stunter38's Avatar
first the spektrum module is only dsm and will not work with dsm2 recievers . yes hk has only dsm2 recievers . obviously these are knock offs but still work . spektrum only had dsm technology at the release of the m8/m11. there is nothing that is forward compatable . the new spektrum radios however are backwards compatable . the new dx4s is a dsmr radio that is compatable with any spektrum reciever.
stunter38 is offline
Old 03-25-2014 | 09:07 AM
rregl0612's Avatar
This might be a dead thread, but from the recent research I have done, you should be able to buy the orangerx board, non module and install it I. The m8! I am in the thinking decisions of currently doing this, and have found one YouTube how to, basic but it gives you the idea. If I try it I will update progress here, Compatibility of the system is any dsm2 spektrum reciever, and the orange rx recievers at $9 seem tempting!
And if your curious the orangerx is just hobbyking branded Corona systems, which have a ton more feedback on plane forums!
rregl0612 is offline
Old 05-17-2014 | 08:09 PM
kinetisist's Avatar
orange rx has QC problems .. if you get a good one they work great but if not well anything can happen to your car. I have another option using xps3 AE transmitter and rx and they are very cheap to buy and not hard to mod and no soldering or messing with your radio. You leave it stock so down the road you can do whatever.
kinetisist is offline
Old 05-17-2014 | 08:22 PM
choisan's Avatar
I still have some brand new tx m8 modules 27 & 40 with brand new receivers. Let me know if anyone interested. Best offer
choisan is online now
