Problem with Turnigy Servo Tester
Greetings peeps,
As you might know this is my first post so I'm sure I'll feel welcome :D You might have come across this Turnigy Servo tester (silver blue colour, 3 outputs, LED's impossible to look at because of brightness). You might also know it has 3 modes (Manual, Neutral, Auto), in my case Neutral and Auto work like a charm....unfortunatley the manual function is not working no matter how far I turn the dial. I do get occasional jitters, but does not work as intended....I tried this on 5 different servos, Neutral and Auto work, just problem with Manual mode. Any one else faced this? Thanks and nice to meet you all;) P.S: Yes I did also try to test a brushless motor using the brushless testing mode setup, same reaction...problem with the potentiometer perhaps? |
Never mind guys, managed to bring it back to my local hobby store, they were awesome and happily replaced the item...I guess it was a faulty pot like I assumed.
CASE CLOSED ---------------------------------------------- |
| All times are GMT -7. It is currently 05:29 PM. |
