Issue with CC Sidewinder SCT ESC
Ok, please bear with me as I am very new to RC cars/trucks.
I have a Losi SCTE that is running the CC Sidewinder SCT/ 1410 (3800KV) combo. Was running at the track perfectly fine, nothing got hot. Changed the battery, and nothing turned on. So I thought maybe I forgot to charge the fresh battery i put in, so I tried another. Still nothing! I have tried everything I can think of to try to get my ESC to just turn on, and nothing seems to be working. If I plug into my computer using Castle Link, everything links up and the ESC turns on fine. None of the wires are pinched/crimped, batteries are fully charged, just not turning on using the battery. Could it be that just the switch is bad on the ESC? If so, can I just bypass using a switch altogether and just have the ESC turn on (hopefully) by just plugging in a battery? Any help would be appreciated. Truck ran and operated perfectly fine before battery went low and swapped out to fresh battery. |
Originally Posted by Phoenix14
(Post 12201829)
I have a Losi SCTE that is running the CC Sidewinder SCT/ 1410 (3800KV) combo. Was running at the track perfectly fine, nothing got hot. Changed the battery, and nothing turned on. So I thought maybe I forgot to charge the fresh battery i put in, so I tried another. Still nothing! I have tried everything I can think of to try to get my ESC to just turn on, and nothing seems to be working. If I plug into my computer using Castle Link, everything links up and the ESC turns on fine. None of the wires are pinched/crimped, batteries are fully charged, just not turning on using the battery. Could it be that just the switch is bad on the ESC? If so, can I just bypass using a switch altogether and just have the ESC turn on (hopefully) by just plugging in a battery? Any help would be appreciated. Truck ran and operated perfectly fine before battery went low and swapped out to fresh battery. http://www.radioshack.com/product/in...ductId=2062485 |
On the side of the ESC is a sticker that says "Castle Creations"
That's your problem! |
Thanks Hoyt, that was the problem. Gonna hit radio shack tomorrow for a new switch. And Nexus, I'm slowly coming to the realization....
| All times are GMT -7. It is currently 11:36 AM. |
