RX8 Settings
Old 05-11-2013 | 04:46 PM
Default RX8 Settings
I did a forum search and didn't come up with anything.
My question is what number values are associated with each setting on the RX8? It says Drag Brake 1-13, but what are the %'s? 1 means "OFF", but what do 2-13 mean? It's the same for Brake Strength, Limiter and Neutral Width. Is each number 5%, or 10% or ??? I really don't want to purchase a Hotwire if I don't have to. I'm only a casual racer.
I read and re-read the manual, and couldn't find it. Does anyone know, or know where I can find this information?
Or can anyone give me the corresponding #'s to the following set-up?
Drag Brake - OFF
Brake Strength - 80
Limiter - 80
Neutral Width - 5
Or maybe give me your set-up for a SCTE with RX8/Pro4 4600kV.
The other 3 options are easy, and I've got those set where I want them.
sdtech58 is offline
Old 05-11-2013 | 06:52 PM
T. Herwig's Avatar
Gear your SCTE 14/40.
Drag Brake: 0
Brake Strength: 80
Limiter: 80
Neutral Width: 15
Voltage Cutoff: 2S
Motor Type: 1
Throttle Profile: 3
No timing.
This is the exact setup I run in my SCTE and couldn't be happier with it.
T. Herwig is offline
Old 05-11-2013 | 07:14 PM
Thanks. What are the numbers (1-13) associated with each of those settings?
sdtech58 is offline
