dx3e and spektrum 3000 binding
What am I missing here, Ive followed the instructions and the rec wont bind.
Can someone walk through it? Its just a blinking green light. |
um I'm trying to reset the receiver by pressing the green button down but it just continues a steady flash
Are you holding the button on the receiver down before powering it on? Do you have the black wire to the outside on the servo plugs into the receiver?
Originally Posted by Dave H
(Post 12042012)
black wire to the inside I believe I will hold down the green button, plug in the battery, it flashes I hold bind button on radio, power up until it blinks and let go of bind button and the radio light goes solid Ive released the green rec button at different times while Im powering everything up and it still just flashes Will it get power if I put the neg wire towards the outside? Thanks for your help, I feel stupid but Ive never had to mess with receivers. Sorry:blush: |
Is it flashing a couple times per second? It flashes faster when the power is applied backwards.
Black-negative to the outside. It is marked on the case if I remember correctly, just hard to see. |
that was the problem I really appreciate it I reverse the battery cables and it worked I was getting frustrated thank you.
Good to hear you got it going. The markings could be more obvious, this is not an uncommon issue.
| All times are GMT -7. It is currently 01:14 AM. |
