ESC problem
I have a LRP TC Spec esc, After 5-8 mins of driving it will stop the 2-3 sec later it will pick up again. I think it is overheating. I am running it with a vector x11 3.5turn brushless motor on a stock gear ration 2wd slash. Any pointers would be greatly appreciated.
My guess is you are way overgeared, surprised you get 5-8 minutes. A 3.5T is a lot of motor for a short course truck, even geared correctly I suspect it will be challenging to keep temps in check for that length of time. Overheating will demagnetize the rotor and possibly burn something up, ESC and/or the motor.
Suggest getting a more reasonable motor, perhaps in the 8.5 to 10.5 range, and work on gearing. If you must have insane speed consider a 3S or higher voltage setup, likely need a different ESC and motor to do that.
