Thunder T8 200W Duo
Does anyone else have this charger yet. http://www.hobbypartz.com/73p-t8duo-charger.html
It says my battery is charged within 10 or 15 seconds. No matter how I set it. I have the balance board plugged in the right way, it is reading voltage, however it says full very quickly. And it is no where near full.
2S 6000Mah shows 7.71V Any thoughts on how I need to set it?
I'd be happy to find out where you got the balance connectors. I have the charger and have only used the 'normal' charge mode since I have no balance cords. Normal mode seems to work fine for me but I'd like to get my LiPo's balanced.
http://www.hobbypartz.com/balancing-jst.html
Or you can just plug the lipo balance lead into the pins on the side of the charger. Balance board is easier though.
Near the bottom of this page http://www.rcaccessory.com/bantame-s...pocharger.aspx there is a PDF file (right above related products on the left) you can download. Its not the Thunder T8 but the Bantam BC8DX which I believe is the same thing.
