Originally Posted by Rsickles
(Post 11945258)
A Rx LiPo Cutoff is a great way to send a car tearing off into the woods. At that point you're reliant merely on the throttle return spring, which is supposed to be a worst-case-scenario option, not something to rely upon. Never mind brakes.
If you're worried about over-draining your LiPo, you're not charging it enough, or running some puny undersized capacity LiPo. It's just that simple. Charge it more. Or if you want to physically run the battery to its limit, that's just dangerous and reckless. I'll gladly take accidentally over-draining a $20 LiPo over destroying a $400 engine and potentially hurting someone. |
Originally Posted by mxr17
(Post 11947220)
Why don't you just use one of those battery level indicators, they just let you know how much juice is left in your battery without the danger of a lip cutoff, if you are scared to not know where you are at with your battery, this would would be a cheap way to go.
http://www.amainhobbies.com/product_...-Warning-Alarm |
Switch to a Life battery is a good option I didn't see in this thread. Sure the voltage is a touch lower than straight Lipo but that's really not a big deal. No worries about running it too low because it can handle very low voltage that would make the servo's noticably slow and easy to see\feel. 1700mah can be had quite cheaply from Hobbyking or a little more at Amain.
(Post 11945258)
If you're worried about over-draining your LiPo, you're not charging it enough, or running some puny undersized capacity LiPo. It's just that simple. Charge it more. Or if you want to physically run the battery to its limit, that's just dangerous and reckless. I'll gladly take accidentally over-draining a $20 LiPo over destroying a $400 engine and potentially hurting someone. I run a throttle return spring regardless of the type of battery in use to insure that my car engine will return to idle speed if something goes wrong. Lee |
| All times are GMT -7. It is currently 07:27 AM. |
