lrp x12 cogging
Hey guys,
I have a cogging issue with my lrp x12 octa 8.5t. Basically intermittently from a stand still the motor wont move, with or without a load on the tires. If you just tap the wheels then the motor spins, on the track when this happens it feels like I go from 0% throttle to 60% once it picks up even if im at 20% throttle. I have tried 2 new lrp sensor cables, my esc is a backup lrp sphere comp. When this happened I installed my novak 17.5 and the problem went away. I also noticed reseating the sensor fixes it for a while. Im guessing I need to replace the sensor or is there something else going on? Using the stock 12.5 rotor, someone mentioned before to make sure its shimmed right because they have a lot of magnetic force but cant find that reference, it was a EU page.
Please advice before I spend $15 on a sensor
