FlySky FS iT4 Transmitter Thread
#421
it is in immaculate condition and will include the stock telemetry reciever and sensors along with a brand new 1st generation reciever and 2 used ones. I was thinking about $130 for the whole combo but make an offer and if you only want one receiver or however many let me know!
#422
hey everybody,
got my chip Friday and I have to say...wtf??????
I really can't believe they think this is an appropriate fix to their problem.
I mean seriously, not everyone out there is an electrical engineer with vast
soldering experience.
I don't know about the rest of you but my knees start knocking when I think
about trying to remove and install these chips.
sorry for ranting here, but I am totally disappointed with the support regarding
this issue.
anyway, hope I can do this or I've got a nice paperweight. or I might just use
it for target practice.
wish me luck!
this issue.
wish me luck!
#423
hey everybody,
this issue.
wish me luck!
this issue.
wish me luck!
#424
LOL my norton just quarantined the flysky firmware update.
#425
I too had to turn off Avast to get it to download. It comes through as spam, spyware do to it being an unknown .exe file.
calchef,m not really that hard. If you have any type of magnification, that really helps. I used my old head band type glasses.
If you have something like this, is all you need.
http://www.radioshack.com/product/in...7&locale=en_US
This makes pulling the old chip easier.
http://www.radioshack.com/product/in...uctId=12580047
If you have the flux in the can, you can make your own by rubbing the flux on some bare strand wire and using it as solder wick. That is how I did it.
Here are a few videos on soldering.
https://www.youtube.com/watch?v=J0AVuqSZvg4
https://www.youtube.com/watch?v=urGB_IUXSIM
Buzz.
Buzz.
#426
thanks for the tips guys. i'm going to practice on some old computer boards I have
lying around and see how it goes. and at 49 any and all magnification will help.
I guess it's just the fear of never doing this before.
thanks again for the input and wish me luck, here goes nothing.....
#427
#428
Buzz.
Buzz.
#429
My worse fear was overheating and melting the board. I tryed a piece of the braided but was scared I was going to cook it. With the new tip I just put in my station not knowing how long I could sit on an area. So I did away with the braided wick. I didn't know they made the stuff with flux in it or I would have tryed it first. ^^^ I was in your shoe's not knowing if I would wreck the whole board and be calling on Jerry to help me out. But you never will know if you can do it till you try it.
I've used mine for a pack in my basement drifting my RS4 mini around. Probably about 10 minutes of run time. No issues yet...
I also switched it over to the WR8 and blasted it around. It is working great. Now I just need to dial in all my trims and end points for the different models. It is pretty nice that I can set it and switch models without needing to rebind and dial everything back in.
#430
unclecrash, what flux did you use that corroded everything? only stuff I know of is an acid flux. You have to remove all of it or it will eat the parts up.
I have an "OLD" tin of no corrode flux. I have had it well over 20 years and going strong.
http://www.amazon.com/C-R-Laurence-N...o+corrode+flux
Mine is in an actual metal container. Shows how old it is. I do have a small tin of acid flux too. I use that on the stainless, hardened wire, and some silver solder. Takes a bit of scrubbing to get all of it.
The parts now take a fair bit more heat then they used to.
Buzz.
Buzz.
#431
#432
Buzz.
Buzz.
#433
You do not have to clean it up after you solder. Yet cleaning it up is a good idea. just makes it look good. Also get a good solder.
http://www.amazon.com/Kester-Rosin-C...in+core+solder
Buzz.
Buzz.
#434
Buzz.
Buzz.
#435
How did it work out for you? Is it working properly?
