HPI Apache C1 Electronics Help! >
Old 01-21-2013 | 10:15 PM
Default HPI Apache C1 Electronics Help!
So my HPI Apache stopped working today for some unknown reason. With a fresh set of batteries I get absolutely no power to the esc/motor/steering servo/receiver. No leds on the esc or receiver. I hooked the esc up to the castle link and all leds are on and everything looks ok in the settings.
I'm assuming my esc is bad but want to make sure i'm not overlooking something because It's late and I'm tired.
Hasbeen2 is offline
Old 02-04-2013 | 11:25 AM
I had same issue.
When u turn it on, does the ESC just beep with all three LED's flashing?
I read and read and read and tried all the troubleshooting. Bit the bullet and brought it to local hobby shop. Turn out the wire that runs from the ESC to the receiver was bad. They soldered a new one on and it runs like new.
I beat on it all day yesterday with zero issues. Hope this helps!
Kevin
San Diego RC is offline
Old 07-24-2013 | 02:42 PM
Mine did that before. I just unhooked everything (battery's, esc..etc) then reconnected. Then it worked as normal
tktodd is offline
