Strongest double sided tape? >
Old 01-26-2013 | 06:00 PM
  #16
3M VHB heavy duty. 1" clear w/red backing. Works very well!!!
Got mine at Office Max.
Andy Koback is offline
Old 01-26-2013 | 10:58 PM
  #17
I have not seen the clear? the one I use is from the auto parts store mostly used for car body moldings
RcNuttz is offline
Old 01-27-2013 | 01:40 AM
  #18
I'm pretty sure the Parma stuff is just 3m clear VHB.
PROMODVETTE is offline
Old 01-27-2013 | 06:57 AM
  #19
jlfx car audio's Avatar
Top stuff is nice but the 3m body molding tape is where its it. Paint supply shop sells it for 15 a 50' role here
jlfx car audio is offline
Old 01-27-2013 | 07:25 AM
  #20
CarbonJoe's Avatar
Regional Moderator
This. Available just about everywhere in the US (WalMart, KMart, Home Depot, Lowes, etc.). Holds great, easy to remove when you need to.
http://www.scotchbrand.com/wps/porta...6604493&rt=rud
CarbonJoe is offline
Old 01-27-2013 | 07:40 AM
  #21
reptile's Avatar
I like parma clear it won't hold the best when you first use it but after it's been on a few days it's stuck like glue and the great thing about it when you have to remove it you can much easy than the foam stuff...i hate that foam stuff!!!
reptile is offline
Old 01-27-2013 | 07:44 AM
  #22
matt*strike's Avatar
Give it a good press at first and its great. Love how easy it comes off.
matt*strike is offline
Old 01-27-2013 | 09:15 AM
  #23
Pete Vitale's Avatar
Another vote for parma tape!
Pete Vitale is offline
Old 01-27-2013 | 09:54 AM
  #24
i'm surprised at how much you guys like the parma, I was at the track last week and bought some to installed the receiver with it and 1/2 pack later it came off I cleaned the surfaces and did give it a good amount of pressure to secure it too
the 3M body molding is really the best I used but does not come off as easy as the parma stuff but is not as bad as the foam tape if you take your time pulling it off
they guys using the parma are you on road or off? (i'm off road)
RcNuttz is offline
Old 01-27-2013 | 11:11 AM
  #25
I use the 3m gray stuff when something is to be stuck down near permanently. But most of the time I use the 3m clear since it comes up much easier, and it sticks pretty darn well if the surfaces are good and clean. It's the stuff Walmart sells in the hardware/paint dept.
Manning is offline
Old 01-27-2013 | 11:26 AM
  #26
reptile's Avatar
it will come off easy when first put on ...Like said above press it down hard wiggle it a hair back and forth and hold it down for a while it will stay better but i noticed once you have it on for a few days it sticks on and won't come off.
reptile is offline
Old 01-27-2013 | 11:44 AM
  #27
Got it at Office Max.
Old 01-27-2013 | 11:55 AM
  #28
rcfanatic573's Avatar
I know it sounds wierd but most of us at the track I race at use a little shoo goo for the heavy stuff. I use it on everything in my 4WD sc truck. I have never had it fail me and when it's time to remove the electronics a little twist to free it up and you can usually remove the piece and then peel off the remaining shoo goo in one piece.
rcfanatic573 is offline
Old 01-27-2013 | 12:33 PM
  #29
reptile's Avatar
I do this also on some stuff workes great... only thing i like about the parma clear is it makes like a shock proof cushion to protect your stuff better.
reptile is offline
Old 01-27-2013 | 03:56 PM
  #30
If you have deap pockets Kyosho Zeal Tape is also awesome for 4x4's and 1/8 can save your ESC
Manatarms25 is offline
