Havok pro sc hall sensor help
When running the hall sensor test, the blue light doesn't come on. This was the case when I first started having issues with the truck not moving from a stopped position. Almost as If it was a sensor wire issue. I figured it was the sensors in the motor, so I put a new ballistic in with a new sensor wire. Still having the same issue. The hall sensor test is not showing a blue connection. From stop, it sometimes doesn't want to go. When I give it a slight push, it moves and runs fine.
Any thoughts or ideas? |
Originally Posted by ssallenbach
(Post 11704406)
| All times are GMT -7. It is currently 08:29 AM. |
