Question about crystal >
Old 01-19-2013 | 06:44 PM
Supashawn's Avatar
Default Question about crystal
Is it possible to use an AM crystal in an FM transmitter? I have a buggy with a Futaba transmitter running 75 AM an obviously do not get a lot of range. Wondering if I can swap crystals to AM 27 to get more range or will I have to buy new trans/rec?
Last edited by Supashawn; 01-20-2013 at 10:34 AM. Reason: I am a noob. Corrected 75 FM to 75 AM
Supashawn is offline
Old 01-19-2013 | 07:05 PM
hotrod87's Avatar
No these are incompatible.
hotrod87 is offline
Old 01-19-2013 | 07:17 PM
I have run Futaba 27 mhz, 75mhz (AM and FM), and PK3 with Spektrum module and Spektrum receivers. Never had an issue with range on any of them. I run indoor and outdoor. Maybe there is another issue. Could be cracked crystal, loose pin in receiver, or bad antenna wire, or antenna wire that has been cut.
nutz4rcyktw is offline
Old 01-19-2013 | 07:42 PM
Supashawn's Avatar
Thanks guys. I might replacing the crystals to see if that will work as it seems everything else is in working order. Seriously though; last time I drove it I could about 20 yards max and the buggy would start spazzing on me.
