Using 7.4v servo - power supply options? >
Old 01-24-2013 | 11:48 AM
  #16
dtr's Avatar
dtr
Originally Posted by saturnv7890
Correct me if I'm wrong, but it's most likely because of voltage sag. When a car undergoes hard acceleration or braking, the battery will be under a load it may not be able to keep up with fully, thus the voltage potential on the battery drops temporarily. Because of these voltage differences, this may harm a servo or cause erratic behavior. And BEC's are cheaper than having to buy another servo, even if it is only $15
Battery voltage should only drop a few tenths of a Volt, that shouldn't matter to any servo. BEC voltage can drop more than that under load from the servo, it would be nice if you could share some measurements from yours.
dtr is offline
Old 01-24-2013 | 12:10 PM
  #17
All my info is based on what I've read in this thread and forum. I don't have any data logging equipment to determine voltage drop, I might be able to getting a reading with a volt meter?
saturnv7890 is offline
Old 01-24-2013 | 12:57 PM
  #18
I have attached a table with amp draw from a savox 2271sg. As you can see it doesn't draw that many amps. What actually happens based on my experience with my data logging is that the combination of the motor and servo amp draw is too great for the receiver and there is a subsequent brown-out.
ufoDziner is offline
Old 01-24-2013 | 02:30 PM
  #19
Do you have any data about voltage fluctuation on the battery or bec?
That is very nice information though!
Old 01-24-2013 | 03:05 PM
  #20
I have amp draw and voltage for the battery that I can post later tonight. Then you can see how low it gets.
Old 01-24-2013 | 04:36 PM
  #21
What esc,rx and servo are you using?
What voltage is it running at?
Sorry just noticed to posted the servo model
eazy70 is offline
Old 01-24-2013 | 04:56 PM
  #22
sounds perfect thanks!
Old 01-24-2013 | 09:26 PM
  #23
Here are 2 short runs that show voltage drop. There is about a 1v swing, which is what my system hated. I'm using an MT-4 with a Novak Pulse (these tests were done with a Havoc Pro SC) and a Trinity 4XS 3800. One of these was done with the 3800 and the other with a Novak 8.5.
Old 01-25-2013 | 05:53 AM
  #24
Thanks great info, very cool.
eazy70 is offline
Old 01-26-2013 | 02:50 PM
  #25
Well there we have it! So BEC's are the way to go
Old 01-26-2013 | 04:57 PM
  #26
Unless you're running a HV servo. That is because the BEC can only provide as much voltage as the battery is capable of producing. If you're running an external BEC at 6 volts, you shouldn't have any issues. If you're trying to get 7.4 volts to the servo, you can see that the battery is incapable of maintaining that (at least in my case). Which is why I run a separate battery. One of these at 13g, you'd never even notice the weight and never have to worry about anything.
