PL6 + MPA charging current problem
I used the search button but could not find a suitable answer.
I have a PL6 and MPA parallel board. When I tried to parallel charge 2 x 5600mAh 2s lipos the max current it was using was 2A.
1. xh/eh mode selected.
2. DC supply set at 24V 40A
3. LiPo generic High Power preset with a change in current to 1p = 20A 2P = 40A
4. 2P selected when asked for number of packs being charged.
5. charge only mode
6. balance Lead plugged in.
7. I did RTM and feel I have followed the necessary steps.
Please help. I hate being one of those all the gear no idea types with this thing.
Thanks.
5. charge only mode
Thanks.
Yes, one lead per battery. Thanks, Good call on the voltage, I did not consider checking as they are brand new batteries. Will have a look tonight though. Now where did I put that 9V battery for my multimeter...
I did not try one cell. Will try tonight. Thanks again.
Not one cell, but one pack (you said you're running 2S packs). It could be that one of the balance taps or part of the MPA board is bad.
