Dx3c radio help?
Hey guys so i am running a spektrum dx3c with a spektrum sr3000 and every time i turn my sct or my buggy on, the steering is messed up. i fix the trim on the driver stand and race, but when its time for my next qualifying, it is messed up again. any idea what is causing this? i have changed my recievers and my servo's, so i do not know what else it could be but the transmitter. also, what remote feels most like the spectrum dx3c, that is reliable? i really like the feel to this remote, and i cant find another one like it. i was thinking the airtronics mt4, but what do you guys think?
Thanks!
Thanks!
Try re binding the transmitter to the receivers, make sure you're using 2 different model memories between the sct & buggy.
When re binding make sure your end points are both set to 100 for left and right, make sure your trim is set to center and then use "sub trim" to get the steering centered before making any trim adjustment.
Be sure to re calibrate your esc's to your radio after the re binding process.
Cheers
Rob.
Cheers
Rob.
