Help buying charger
Old 12-26-2012 | 08:21 AM
Default Help buying charger
Been looking at the onyx 245 and the trakpower vr1 i will be charging lipo only 2c 7.4 5000mah 30-40c will either one of these chargers be good if so witch would be better also is there any dual chargers thats im over looking that would be better looking to stay under 200$ thanks for any help
jrk078 is offline
Old 12-26-2012 | 08:34 AM
racer1812's Avatar
Super Moderator
you might want to watch this before going with the trackpower.
http://www.youtube.com/watch?v=3i0DiVHXFOc
Do you have a power supply? Do you need it to be AC/DC? How many amps do you want to charge at on each channel?
racer1812 is offline
Old 12-26-2012 | 08:35 AM
Pulse_'s Avatar
icharger, hyperion.. The duo series are great
Pulse_ is offline
Old 12-26-2012 | 09:03 AM
Yeah dont believe i like the trakpower what i need is somthing pretty fast a single charger may wotk for me but i race three differnt trucks go threw several battries a race and the charger i got now takes forever it cant keep up cant think of thename of it thanks for posting the video so i didnt make that mistake
jrk078 is offline
Old 12-26-2012 | 09:52 AM
Suspended
Hi jrk.. I race 3x a week..I run several different chargers..most retail well over $250.. I run a venom charger called a 610 duo..it will charge 2 different batteries at once each at 10 amps max..it is made in several different versions or relabeled by many..ie..Sky rc imax B6 200w--ProTek--Prodogy 610 duo--also a few other company's relabel..about $130.. u will need a 12v 25 amp power supply to run..easy to make from a 600watt computer power supply for a total of $25--thats the 5$ in parts to convert it..
I run from 4500mah to 6700mah packs..all 2 cell (2s)..I take 1700mah out of a pack and to recharge is 22 minutes..this doesnt have the ir let down..
Carpet Racer69 is offline
Old 12-26-2012 | 10:22 AM
Theibault's Avatar
It's pricey, but I LOVE my Orion Twin Spec. Two channels, each can charge up to 20amps, and discharge up to 10amps. With 2 batts charging at the same time, up to 10 amps each. It needs a good power supply, the ProTek 40 is what I use so I can hit 20amps on my bigger packs. I like it so much I'm seriously debating getting a second, but that's money I can spend on other stuff .
http://www.teamorion.com/advantage-twinspec.html
Theibault is offline
Old 12-26-2012 | 10:30 AM
Pulse_'s Avatar
720inet3 duo
Pulse_ is offline
Old 12-26-2012 | 08:15 PM
JRK078,
I'm in the same boat with picking a charger although I will have some NiMH's to charge as well for a 25+ yr old buggy...I refuse to update the ESC and the motor unless I'm forced to.
Tower has the Onyx 245 for $110 and with a code you could get $10-15 off that. The ones that others have mentioned are considerably higher and I would rather spend my money on more LiPos....especially if you don't need high S batteries or need charges immediately but then that decreases the life expectancy of the LiPos anyhow.
Scottypiper is offline
Old 12-26-2012 | 11:02 PM
I ordered the onyx 245 today read alot of good reviews i couldnt afford having to buy a charger and power supply i like that the 245 is just ac/dc
jrk078 is offline
Old 12-27-2012 | 08:36 AM
Hoese37's Avatar
Have it and love it!
http://www.hobbypartz.com/26p-ultimate800-charger.html
Hoese37 is offline
Old 12-28-2012 | 04:34 PM
Doesn't bother you that it doesn't discharge? Just curious. I had some people talk about that as a con for the 245. I like the features and tower dropped the price on it. So I can get it for under $100 - which I think is a good deal but I'm still wondering the need for the discharge function that people say they need.
Old 12-28-2012 | 04:40 PM
Originally Posted by Hoese37
$149 for a dc only charger? You have to get a DC power supply for $15+. That's pretty salty for having to tote around two items to charge your batteries isn't it?
Old 12-28-2012 | 06:27 PM
i here good thinks about the skyrc
http://keithbradleyboats.freeforums....lies-t247.html
Firehawk548 is offline
Old 12-28-2012 | 08:29 PM
Hoese37's Avatar
Yes its DC only. Any charger with decent specs is still gonna be DC only. 98% of all chargers now that are AC/DC are capable of only 6A of current. This cahrger will do 20A on each side upto a 6S/22.2V pack. Thats a total of 40A. Your best AC charger will only do approx. 2.2A on a 6S.
Hoese37 is offline
Old 12-28-2012 | 08:44 PM
EricW's Avatar
R/C Tech Elite Member
Depends on what you're trying to charge.
EricW is offline
