Like Tree8Likes
Lap Timing Decoder
Old 08-13-2014 | 06:17 AM
  #436
howardcano's Avatar
Originally Posted by OM2KW
Hi Howard,
i do not have access to decoder now, can you or anybody test to generate the same number with different 'ghost bits' and check which of them works ?
I only have access to MyLaps and AMB decoders about once weekly, and then all of my time is spent racing (usually four or more classes!).
howardcano is offline
Old 08-27-2014 | 09:41 AM
  #437
Hi,
if anybody is interested in this project, I have a few PCB's here.
When I ordered them I got a few more delivered.
It's Cano's Layout as you can see in the pictures.
Just PM me and we talk about the price and shipment (I live in Germany).
Mike
Attached Thumbnails Lap Timing Decoder-img_9317.jpg   Lap Timing Decoder-img_93181.jpg
walsmi is offline
Old 09-25-2014 | 08:38 AM
  #438
Originally Posted by snoopyrc
Ok. I don't know enough about it. I was thinking of it more as shielding the concrete than the loop. Stacked as concrete, shield, loop, and carpet.
(Edit: Or if using a bridge; concrete, shield, carpet, transponder, loop.
Can shielding material be bought in sheets? Surely guys who do car stereo installations use something like that.)
I haven't chimed in, but I have been lurking. I have an RC4, but it was very hard to come by. I think the club for who can be a race director is too exclusive, too expensive, and just too difficult to get into. You and this thread. You have kicked a door open, for those who may not be loaded, but are determined or otherwise able to do it. You have made a way.
Decoders should be five or six hundred bucks. Transponders less than forty, but that is just my daydream. You are doing a good thing here. I wish I had more to contribute than my encouragement.
Hi Snoopy,
i had the same thought as you to shield the concrete, i am in the process of building my decoder now since i did not get aoround to it all summer. So once its built i will test on a concrete floor.
As for this equipment being too expensive your absolutly correct considering how cheap components are! There should be a low cost alternative and this one is the way especially considering that Howard has designed an inexpensive transponder, we can just build our own systems and transponders.
rc-demon is offline
Old 09-25-2014 | 08:40 AM
  #439
Originally Posted by walsmi
Hi,
Mike
Hi Walsmi,
I also have extra decoder boards, but no transponder boards. I would be interested in buying some of your trasnponder boards! PM me.
thanks
rc-demon is offline
Old 10-03-2014 | 08:06 PM
  #440
Hello Howard,
I am in the process of building my board finally!
A question for you, concerning the Crystal that goes in XTL61, there are 3 holes. Which holes do we use?
thanks
rc-demon is offline
Old 10-04-2014 | 03:25 AM
  #441
howardcano's Avatar
Originally Posted by rc-demon
Hello Howard,
thanks!
Use the square pad and the middle pad.
Old 10-04-2014 | 10:04 AM
  #442
Thanks Howard for previous reply.
I believe there is an error in the BOM, for reference C67 & C68 it says quantity 4 but only 2 are needed?
rc-demon is offline
Old 10-05-2014 | 06:10 PM
  #443
Hello Howard,
For the serial connector, im looking at schematic and I dont see any information about it.
At jumper J65 (square) I assume is data?, what pin does it goto on the serial db9? (TXD 3) ?
and round to what pin on db9?
rc-demon is offline
Old 10-06-2014 | 05:48 AM
  #444
howardcano's Avatar
Yes, the quantity for 22pF is incorrect.
J65: square pad is data out, round is ground. The wiring for the DE9 will depend on what you are connecting to, but here are some typical connections:
http://pinouts.ru/SerialPorts/Serial9_pinout.shtml
Old 10-06-2014 | 10:32 AM
  #445
thanks for the reply. I am connecting to the serial port of a Laptop or PC to use with timing software.
So it would be pin 3 & 5 on serial connector? (TXD & GND)
rc-demon is offline
Old 10-06-2014 | 01:59 PM
  #446
howardcano's Avatar
I'm using pins 2 and 5 to connect to the Sabrent SBT-USC6M USB to Serial Adapter Cable.
If you are using FlipSide scoring software, you will also want to connect pin 1 (square pad) of J66 to the incoming RS232 data (pin 3 on the DE9, in my case). This was a last-minute change requested by FlipSide; any character received by the decoder will reset the internal timebase counter.
Old 10-06-2014 | 04:44 PM
  #447
Im not sure i understand why your using pin 2 on the serial connector since thats to receive data, isnt the decoder sending data to PC ? so it should be pin 3 (transmit data) ?
Thanks for the clarification on Flipside! I dont think im going to use it so far looks like i will go with Zround timing.
rc-demon is offline
Old 10-07-2014 | 03:05 AM
  #448
howardcano's Avatar
The labeling is for the connector on the PC. The PC receives data on pin 2, so that's where the decoder needs to send it.
Old 10-07-2014 | 12:13 PM
  #449
silly me! i had things backwards, i fully understand now. thanks for clearing that up.
rc-demon is offline
Old 10-07-2014 | 02:59 PM
  #450
howardcano's Avatar
It's not just you! If I had a dollar for every time I've had to unsolder and swap RS232 transmit and receive lines, I'd be sitting in Hawaii right now.
