Originally Posted by carcrusher46
(Post 11943019)
Our local track personnel talked to some folks at MyLaps the other day on the phone and they're claiming that the plan is to have the entire system limited to the 3-wire MyLaps RC4 transponders ONLY by 2017. House Transponders, AMBRC Personals, and even the RC4 Hybrid apparently are going to be phased out over time and the compatibility will be eliminated via automatic software updates when you connect the box to upload peoples' laps online.
FEEDBACK APPRECIATED RC2 TO RC4 DECODER
THIS IS ABOUT THE DECODER NOT TRANSPONDERS
OK we are wanting to switch from the rc2 decoder to the new rc4. For tracks that have upgraded from the RC2 DECODER to the NEW RC4 DECODER was it a easy change over, things like software, hooking up wires are there any snags we need to know about. Thanks in advance |
Everything works the same, just the loop field strength is alot more, so there is a setting on the box to adjust it (squelch).
With the new functions of the decoder and the transponders, your software manufacturer may tell you to use ethernet vs the serial port. They have to make changes to the software to read the decoders extra functions, and may only supoport the ethernet port vs the serial port.. Check with them on which one they recommend. I have used either, and everything works fine with the software I use. The book says to make the loop 2ft wide, RC2 book said 1 ft wide, we kept it 1ft wide and havent had any issues at all, and MyLaps said that was ok. |
(Post 11943019)
Originally Posted by Shiloh
(Post 11956273)
It sounds like a way to phase out small clubs as well. AMB does not have the racers' best interests in mind. New racers will not buy a personal transponder for their first few races. They will need to be able to borrow a house transponder initially. The RC racing community really needs to deploy an open source counting system.
The problem is now and will always be that bigger organized national type races will use a lap counting system partner. Right now that partner is Mylaps and will probably be for some time, at least until somebody gets bigger and supports the RC racing community better. Maybe if somebody else made a nice system that was affordable and worked good all the tracks would switch over. |
Originally Posted by JimmyG
(Post 11976526)
With the new functions of the decoder and the transponders, your software manufacturer may tell you to use ethernet vs the serial port. They have to make changes to the software to read the decoders extra functions, and may only supoport the ethernet port vs the serial port.. Check with them on which one they recommend. I have used either, and everything works fine with the software I use. The book says to make the loop 2ft wide, RC2 book said 1 ft wide, we kept it 1ft wide and havent had any issues at all, and MyLaps said that was ok. Sorry JimmG your loop is not 12" its over 24".. its more like 30" |
(Post 11956273)
Originally Posted by hpikillr
(Post 11979381)
(Post 11943019)
If so does that require you to use their timing system exclusively? |
Originally Posted by RussF
(Post 11979357)
The owner says he has no plans of changing to the new RC4 system because there is absolutely no benifit to the club or racetrack to change. The only benificary is Mylaps getting $$ from the track and the racers.
The argument to upgrade because it's a deal is actually the perfect argument to NOT upgrade. Clearly Mylaps is taking a loss on the decoder boxes to speed up the demise of clones and they know they will make that money back later when we are all FORCED to buy new transponders. |
Originally Posted by asc6000
(Post 12004504)
That is a smart track owner. There is NO advantage with the rc4.
The argument to upgrade because it's a deal is actually the perfect argument to NOT upgrade. Clearly Mylaps is taking a loss on the decoder boxes to speed up the demise of clones and they know they will make that money back later when we are all FORCED to buy new transponders. It also lets you set the same transponder number for all of your vehicles. You also get some telemetry (temp and voltage) that some racers might find useful. To say there are no advantages isn't entirely true. Maybe none that apply for you.... but that doesn't mean there aren't benefits. |
Does anybody use the MYlaps sports timing system (formerly SPARC). Seem like the real time upload of results and practice would be kinda cool.
(Post 12004504)
The argument to upgrade because it's a deal is actually the perfect argument to NOT upgrade. Clearly Mylaps is taking a loss on the decoder boxes to speed up the demise of clones and they know they will make that money back later when we are all FORCED to buy new transponders. I would bet next year's salary that the transponders cost <$10 to make and the decoder boxes <$200
Originally Posted by cdwilliams1
(Post 12004591)
Well, playing devil's advocate... the new system doubles the data rate - improving the pickup of the transponder signal (especially in carbon based setups). This is also good for track owners since they don't always have to put the loop in the slowest corner for best results. It helps with flexibility in track design and where to place the starting line.
It also lets you set the same transponder number for all of your vehicles. You also get some telemetry (temp and voltage) that some racers might find useful. To say there are no advantages isn't entirely true. Maybe none that apply for you.... but that doesn't mean there aren't benefits. The Temp might be useful for the futaba guy's that have RXs that overheat.:lol: Voltage is completely useless... I can set my MRTs to ANY ### that I want. I've never seen a loop have issues when placed in high speed sections... |
Originally Posted by whitrzac
(Post 12004663)
I can set my MRTs to ANY ### that I want. And since the "bonus 20" numbers available on the MRT's are always the same on every single unit, we've had MRT's conflict with other MRT's at our track. Heard from the local guys that it happened at snowbirds in the past too. Going with a real AMB solves that problem. Another potential advantage to using the real thing.... |
(Post 12004663)
With a MyLaps PT no one will ever have the same number! haha....cdwilliams is as confused (or as realistic) as I!:) |
(Post 12004714)
Again, devils advocate here... (I don't really care either way since I don't have an MRT, my own stuff works and will continue to work) but.... the MRT folks just picking their own number out of thin air has caused problems at the snowbirds in the past where it conflicted with a real AMB number.
And since the "bonus 20" numbers available on the MRT's are always the same on every single unit, we've had MRT's conflict with other MRT's at our track. Heard from the local guys that it happened at snowbirds in the past too. Going with a real AMB solves that problem. Another potential advantage to using the real thing.... Our local track personnel talked to some folks at MyLaps the other day on the phone and they're claiming that the plan is to have the entire system limited to the 3-wire MyLaps RC4 transponders ONLY by 2017. House Transponders, AMBRC Personals, and even the RC4 Hybrid apparently are going to be phased out over time and the compatibility will be eliminated via automatic software updates when you connect the box to upload peoples' laps online. A transponder ## conflict takes 2s to sort out in most racing programs. 404error: problem not found |
| All times are GMT -7. It is currently 02:43 PM. |
