3PK Add New Model Problem >
Old 11-06-2012 | 06:52 PM
Default 3PK Add New Model Problem
I was wondering if anyone could help me with this problem.....this is what I got going on.....I bought a Futaba 3PK with 2.4GHz....I have two r603fs receivers....I got one in a car and it works fine got all the settings right and then I tried to set the seconed one up. So when I get into the M-SEL on the controler it comes up with the one car but wont let me select a new model so I can bind it to the new receiver, its like its locked can move around just cant enter on one of the models.....is there something I am doing wrong or is it my controler....thanks for your time hope you can help
littlehonda14 is offline
Old 11-06-2012 | 07:40 PM
Well after doing more checking and messing around I think I might of got it....I got it to change the model and I got that set now its just if i have both cars on and am on model one they both move is this right or wrong thanks again for the help
Old 11-06-2012 | 07:53 PM
TOM MAR's Avatar
You need to...
Select the model then, Press & hold the + & - buttons at the same time.
Then turn off, then on your transmitter.
That should solve the problem, or visit your LHS. They may be able to help.
Tom
TOM MAR is offline
Old 11-06-2012 | 07:54 PM
TOM MAR's Avatar
Cool, thats good
TOM MAR is offline
Old 11-09-2012 | 08:32 AM
Hoese37's Avatar
the receivers are not model specific. you can run two receivers on the same model.
Hoese37 is offline
