SMC LIPO BATTERY THREAD
#1471
Increasing the mAh is possible but this will come at the expense of IR which will impact the voltage curve and punch of the pack. The current 4600s cycle out at 4500 or so at 35 amps but have very low IR. I believe keeping the IR as low as possible is the way to go.
As far as 5mm tubes go in my testing I couldn't see a difference in the data of the pack. Since most customers are already equipped with 4mm connectors switching to 5mm really makes no sense at this time.
#1472
Typically the mAh is at the rated spec or within 5%. As the factory makes a model at first they give us the estimated mAh it will reach. Then after a few batches the mAh settles in and can be lower or a higher this depends on the IR. Also there is some fluctuation in cells. So if they make 5000 cells rated at 5000 the lowest one maybe 4750 and the highest ones may reach 5250.
The best thing to do is to set your cutoff on the conservative side. Something around 3.50v per cell is a good start. Run the pack until the cutoff kicks in and then measure the voltage of the pack. If your cutoff is working properly the voltage of the pack should be at 7v or a bit over. If it's 7.2v or so you should drop it to 3.4v per cell as this means your cutoff isn't accurate. This depends on how the ESC senses the voltage which has allot to do with resistance and voltage drop.
Recently I had a customer who had is cutoff set at 6.7V and after a run the pack had a cell at 2.9 and the other at 3.4 this means his cutoff isn't working properly. The voltage should always equal the cutoff or be a bit higher.
#1473
#1474
#1476
Yes that is what they told me. Originally they told me the 10th but then yesterday they told me they we're going on a National holiday and my order can only ship on Friday.
If nothing changes this means they will be in by the end of next week.
#1477
We will honor the pre-order price but once the packs comeback in stock we will increase the price by 5 dollars. The new model we will offer will be 5100-40C and the IR will be lower so expect better performance out of the new pack.
#1479
Once I get about 20 charges through my 2 new SMC's I'll measure them again.
#1480
Glad to see your putting the ESR meter to good use. A few things you might want to consider is testing the IR at storage charge then charging the packs at 2C and testing the IR at the end of charge. You should notice that certain packs drop more in IR as they are made using different formulations.
#1481
Danny, I ran my shorty 4600 the other day till it hit LVC. I have it set at 3.2. But when I went to charge it the next day the cells where pretty off balance. Eventually they balanced out ok with them being at 4.18 and the other at 4.17. But it took them a long time to charge. Case is not swelled one bit. Just wanna make sure I didnt do any damage. And this was the first time that I have hit the LVC with that battery
#1482
What was the voltage of each cell when you put it on the charger? Assuming your ESC does cutoff at 3.2v per cell that is on the low side. I've seen a pack be as low as 5.9v with the cutoff set at a 3.2v.
I don't recommend going below 3.4v per cell.
If the pack took charged up and didn't swell it should be fine.
#1483
#1485
Lower internal resistance, more punch, can handle a power hungry setup better than the factory pack.
Yes, you want the race pack for the heavier conversion truck.
11Likes
Not like im going to find a better pack for a cheaper price
