SMC LIPO BATTERY THREAD >
Like Tree11Likes
Old 04-20-2019 | 07:02 AM
  #4261
Originally Posted by cHAmpa
Yeah, the 5000mah are nice.. they sold some a few months ago for testing and I've been running them in buggy and truggy making 10-minute mains.
That is great news, I have been looking into something a little smaller than the 7400mah just for racing. I don't see the 5000mah up yet but hopefully soon they will sell them in the states. Heck now looking they don't even have the 7400mah still for sale, that is one of the frustrating things it seems they are always changing what they sell.
Fate0n3 is offline
Old 04-21-2019 | 04:49 PM
  #4262
Exclamation new lipo battery dead...?
i have a rc car which runs on lipo batteries i have ran the battery for 2 hours for the rc car the rc car is high powered at it was the correct battery but we have tried to charge it and it has not worked we dont know how to fix it any tips?
somedude1212 is offline
Old 04-21-2019 | 05:22 PM
  #4263
Do you have a lipo cut off on the RC car?
What are you using for a charger?
Do you know the voltage currently for the battery?
Mahjik is offline
Old 04-21-2019 | 06:39 PM
  #4264
1: not sure what a lipo cutoff is. The car has run before
2: greedy quick charger can with the rtr
3: 1 battery is .8 the other is 8.4
Old 04-21-2019 | 08:19 PM
  #4265
I'm guessing these are 2 cell packs. The .8 volt pack is probably done, it likely has been over discharged.
Lipo cutoff is an esc feature that cuts off the drive voltage when the individual cells drop below a preset voltage, usually in the 3.2-3.5 volt range. The car will either stop running or noticeably slow, they may also flash indicator lights depending on esc brand.
Did you run the 8.4 volt battery or am I mistaken by assuming these are 2 cell packs?
sweems is offline
Old 04-22-2019 | 06:28 AM
  #4266
While this is a drone link, it's a good article about how to care for your Lipo batteries:
https://www.dronetrest.com/t/lipo-ba...batteries/1278
Mahjik is offline
Old 04-22-2019 | 08:51 AM
  #4267
Yes both packs have been run and are 2 cell. the one pack at 8.4 is running fine. the .8 volt two cell must be toast as you suggested. Both charged with a balance charger
Regarding the ESC im pretty sure it has a lipo safety feature some sort, The car is a RTR by Associated with all Greedy branding/components.
This seems to be operator error. Im old school regarding batteries. I ran both down then charged them for long term storage (thinking lead acid battery).
So im good if i run battery to 3.x V for storage? Also,
Where would I dispose of a LIPO battery?
and, since i need to buy a battery pack, what are your thoughts on a 3 cell pack? gear the car up? (isnt there some inverse relationship regarding gearing and thermal)?
Fyi, im writing this for my son Andy. This is a learning experience for both of us. Im from the 80's with the grasshopper and other old school cars.
TIA, Andy
Old 04-22-2019 | 08:54 AM
  #4268
Thank you for the help. I skimmed this yesterday will reread today.
Old 04-22-2019 | 10:16 AM
  #4269
3.0V per cell would be the lowest to take a Lipo. Typically, you should stop running at 3.2V per cell which is when most Lipo cutoffs solutions will happen. Your storage charge should be 3.8 - 3.85V per cell.
If you have a configurable Lipo cutoff, you could set it for 3.8V which would be your storage charge.
Mahjik is offline
Old 04-22-2019 | 10:57 AM
  #4270
The cutoff would be set in your ESC.
Andy Koback is offline
Old 04-24-2019 | 01:24 PM
  #4271
so i have run the car until it wont run.
With a new Klien meter I am reading 8.18v for a 2 cell pack rated for 7.2 and the car will NOT run anymore.
The Reedy (sorry for mispelling earlier) ESC is blinking rapidily. Im assuming the esc is shot or battery is discharged at 8.18v and the esc is shutting down.
NOW heres the kicker. The car stopped working right after I hit a curb pretty hard.
1) im still not understanding the correlation of V as a measure of stored energy potential at a given point in time(charge). I get small variances in amp out vs V but storage? seems like a very small V variance to work with. Wouldnt time on charge be a better measure? is there a chart showing V to Amp out correlation. wouldnt that be a better measure of stored capacity than V?
2)im going to charge it up .2V and see if i get a run. There seems to be a memory on these batteries within a VERY small V window.
Am I overthinking something? I have read and reseachered but am missing something
TIA
DMW for APW
Old 04-24-2019 | 01:56 PM
  #4272
What are you using to measure voltage of the battery?
Mahjik is offline
Old 04-24-2019 | 08:07 PM
  #4273
Klein Tools MM... one of the best measurement tools available set to 20V DC. Used a cheapie chen-tech meter and both read the same
found out the rapid green blinking is ESC overheat.
Old 04-25-2019 | 06:16 AM
  #4274
Are you reading off the balance lead? It seems extremely odd that you are getting 8V+ for a 7.2V battery. Either it's getting overcharged or something is a miss in how you are getting your readings.
FWIW, there are some easy to use devices that you can use to verify you are getting the correct readings from your multi-meter:
https://www.amainhobbies.com/isdt-bg...d-bg8s/p694594
Mahjik is offline
Old 04-25-2019 | 06:32 AM
  #4275
Kraig's Avatar
Super Moderator
Well most chargers charge the batteries up to 8.4 volts these days so it is not uncommon to see that high of voltage.
For those that don't know, 8.4 volts is the max voltage a person can charge to assuming they are following the rules by the sanctioning bodies.
Kraig is offline
