tekin rs pro problem
i have aproblem with my tekin that i cant figure out..
i have tried new sensor wires, and a new motor. re calibrating the esc a few times, and re flashing it with the hotwire.. problem is, mid run the boost cut out, now its cogging from a stand still, and barely gets going, but once its rolling it runs fine, just feels like its in blinky mode,.. and if i look closely, the 3 little leds in the tekin display that should rotate in sequence that indicate it seeing the sensor, only 2(1&3) are working..? does this sound terminal? any ideas on how i could fix this? thanks.. if this esc's done, so is my racing for a number of months.. |
raise you throttle epa a couple. I had problems with the ESC/radio not seeing full throttle and boost would not kick in or disssapear during a run
Originally Posted by goots
(Post 11376081)
made no difference |
Sounds to me like the sensing on the speedo died. You may want to contact tekin.
| All times are GMT -7. It is currently 04:24 AM. |
