Novak help needed
I have tried to find any thread or any posts regarding Novak speedo's but have had no luck.I will post the problem and hope someone can give me some advise. A buddy of mine bought the sc combo with a 4.5 550 can motor for 4x4 sc and had issues with the speedo after two weekends running it. He returned it to Novak and they sent him a new one sealed in the box,he decided to keep the motor but sell the speedo so I bought it from him for 100 bucks. I kept it in my pit box until I needed it...so when time came I put it in my 0fna 10sc and ran it for two weekends.I race twice a month, I used the 13 tooth mod -1 pinion that is recomended by Novak on their site and the truck ran great. Great until the third weekend racing when it just stopped running.I brought it back to the pits and re-set it and binded it and made sure my glitch buster was on cause I was using a digital servo.After programing it it would steer but the wheels would not turn when I hit the gas. I spun the wheels by hand while holding the trigger and the motor came to life and the wheels spun like they should. If its rolling on the track its fine and has plenty of power but if it comes to a complete stop...it needs to be pushed to go,almost like when using a brushed motor that has dirty brushes. The motor is a speed passion 4.5 turn 550 can motor and I thought that it was the motor issue but when I put in my HobbyWing speed control it worked fine and I finished the race weekend with no other issue.Therefor I figured it was not a motor issue. I called Novak and was told that they cant do anything other than sell me another for 75 bucks if I send them this one back.They claim they dont do repairs and there is nothing they can do. I found that weird cause I always had good experience with Novak but now I got the impression that they dont care.They even had a tech guy talk to me and tell me that its not cost effective for them to diagnose the speedo's. But they do sell refurbished ones on their site...so whats the deal ? Is this something that anyone has had happen to them? is there a fix for it without sending it in? I dont want to pay another 75 only to be told that same thing next time. Also I though of getting it and selling it but how much can I sell it for since they go for about 90 on rc tech. Am I stuck with a paperweight with wires coming out of it ? Any help will sure be appreciated,thanks Pete.
Originally Posted by peter george
(Post 11318594)
Novak has the best service in the industry. I've sent them stuff back that I flat out broke or burnt up and they have replaced it no questions asked. Now, you've got a 2nd hand product with not receipt or warranty? You might be in a different situation. Email Charlie. Let him know what's what - do you have a reciept or the return invoice they include when they send it back on repair?
What model speed controller. The likely reason they sell refurbished ones is that your model may be older and off the current production list. I say use the trade in program and if possible get a newer speedo from their lineup. Will Most likely be more reliable too for that matter. All speedo company's rarely fix damaged speedos, they end up in a heap of junked speedos and a replacement is sent out if available. Grand truck is right because of your situation being second hand and all. Novak is really good and the guy to talk to is Charlie.
Get your friend to send it back since they have the repair record for him . I had the same problem with a havok 3s system the 3rd time i sent it in I sold it when I got it back .
Peter,
Sorry to hear your having problems with your Novak ESC. From the way your descibing it, sounds like the ESC just simply went bad. It happens to the best of us. The only problem I see in your senerio is that you bought it from a buddy, which means you didnt get the 120 warranty. My suggestion would be to have your buddy send it back for you and have it warranty/serviced. I have had many dealings with Novak and they have always been great and have one of the best customer service dept. around. Try shooting an email to Charlie... he's the Man! [email protected] |
(Post 11318594)
([email protected]) Have your buddy do it for you. |
Originally Posted by mojoman81
(Post 11318606)
Is it the havok sc ?
Thanks to all who took the time to respond, gonna try to get my buddy to send it back.
(Post 11319049)
Novak does have outstanding customer service. They truly stand behind what they sell. Check your PM. |
some one pm'ed me that you should not use Speed Passion motors with Novak speed controls.....is that a fact ?
(Post 11321159)
Originally Posted by Mxer59
(Post 11321238)
You can use any sensored motor with the Novak Esc. The only motor that gives problem is the Pro4 if you don't have a newer updated board. I use to run nothing but Novak, from my issues I've only had one Esc go bad another thing to check is sensor wire I've had a few Novak sensors wire go bad, as soon as I plugged a new one in all my problems went away. So it's always good to test that or carry a spare.
I have the Exact same issue on a NEW Novak Activ8 ESC running their 1950KV ballistic 8 motor.
Was running its third battery ever, took it out and it stopped after 15 mins. The car would only move if i Pushed it. Peter George does your ESC have a hall effect sensor diagnostic test? I tested mine and everything checks out ok. Have you also noticed that if you stay on the throttle (even if its not moving), the ESC error LEDs, come up blinking the error code for Motor Rotation Blocked? Mine does that after a few seconds. Lucky for you, your in USA, I'm in Australia.... Would Novak honour my warranty? I bought mine from Amainhobbies. |
Originally Posted by Forgetful_Duck
(Post 11322481)
Was running the first battery ever, took it out and it stopped after 15 mins. The car would only move if i Pushed it. Peter George does your ESC have a hall effect sensor diagnostic test? I tested mine and everything checks out ok. Have you also noticed that if you stay on the throttle (even if its not moving), the ESC error LEDs, come up blinking the error code for Motor Rotation Blocked? Mine does that after a few seconds. Lucky for you, your in USA, I'm in Australia.... Would Novak honour my warranty? I bought mine from Amainhobbies. |
| All times are GMT -7. It is currently 04:26 AM. |
