Hobbywing ESC sensor problems >
Old 10-07-2012 | 01:26 AM
Default Hobbywing ESC sensor problems
Ok so I've got 2 Xtreme stock 60A's and a 120A v2.1
The 2 xtreme stocks have worked for a few months but one started playing up with the mode changing to sensorless. Now sensor does not work at all. I need to give the motor a push to start it revving. and once I stop it will stop and wont go again until I give it another push.
Both the other ESC's have the exact same fault. The 120A lasted one race meet then started doing the same thing. These are all out of different cars with different motors. And I have tried different motors and sensor wires on all so it must be the ESC's.
Has anyone else had this problem with the hobbywing gear. I thought it was pretty good up until now.
Has anyone had any luck with the warrenty service they provide?
Cheers
Jesse
Jesseh is offline
Old 10-11-2012 | 02:59 PM
nitroexpress's Avatar
The way I read their warranty, there is none if the unit has been operated.
nitroexpress is offline
