charging at the track
Don’t go too small, it depends on how fast you are charging, especially the 4S. Lead acids can deliver a lot of current, but the voltage drops significantly under even moderate loads. Can easily drop below the minimum needed for a typical RC charger. Here is a recent similar thread for reference:
http://www.rctech.net/forum/radio-el...uch-power.html
If you stick with your car battery, start it frequently, expect shorter life depending on how often. Did it for years, definitely makes a difference. If you can spring for it a generator is great to have.
