-   -   tekin rc pro issues (https://www.rctech.net/forum/radio-electronics/665949-tekin-rc-pro-issues.html)
jdick 09-29-2012 08:57 PM
tekin rc pro issues
Hey there fellow rctechers
a buddy of mine is having some issues with his rs pro. basically he doesnt get any motor chime and the motor wont work. the middle led shines up and when he pulls the throttle and brake all the lights light up. he has full power to his servo and everything works and was calibrated but he has no motor movement or chime. ive searched around and cant seem to find anything. any help would be greatly appreciated.
its for a 12th scale mod pan car set up if that helps.
fung_kyle 09-29-2012 09:06 PM
I think the deadband is wrong. You can fix this via hotwire.. To check if it's really the deadband problem, i would use the trim to make all the LED's turn off. After that the Rs Pro should chime.
jdick 09-30-2012 02:27 PM
wow i would have never thought of that. thanks for the reply
jdick 09-30-2012 06:39 PM
soo my buddy tried the trim idea with the deadband and it didnt seem to help much. anybody have any other idea? any help would be greatly appreciated
BigRM 09-30-2012 08:50 PM
Have you tried a different motor yet? Everything else is working as it should.
jdick 10-01-2012 04:37 PM
yeah hes tried different motors and used a brand new sensor wire that came with the brand new motor and even different batterys.
mkiiina 10-01-2012 05:23 PM
Mine did this after a bad flash while upgrading firmware. Reflashed and everything was ok in the end.
jdick 10-02-2012 06:40 PM
thank you sir. ill pass the info along
goots 10-02-2012 10:31 PM
check the white wire for a break in connection also
TY@TEAMTEKIN 10-03-2012 07:04 AM
Make sure it's set to the correct motor mode as well. If a software reflash doesn't revive it, it will need to come in for service. You can contact our service team here: [email protected]
jdick 10-04-2012 04:07 PM
thanks for the replys guys. and i think that my buddy is going to try the white wire idea and if that doesnt work then its going to be sent in
