Problem with one of my Lipos?
Hi,
New on this forum. I have several 2s lipos(5000mah 30c) and all work great. One of them wont go all the way to 8.4v on my charger though like the rest. I tried discharging and then balance charging again, but it still won't go all the way to 8.4 volts so the charger will stop and say"full". Any ideas? Otherwise it seems to work just as good as the rest. Thanks |
Sounds like your charger is stopping at a specific mah point, but some packs will take a bit more than the advertised capacity, so if your charger can be adjusted, I'd suggest setting it for a little more(maybe an extra 1000mah above the rated capacity of the pack), & don't worry, the charger should still stop the charge at the right time(as long as it's set in a proper CC/CV LiPo charge mode)....:cool:
I will give it a try.
Thanks |
| All times are GMT -7. It is currently 10:06 AM. |
