help with lipo!
Old 09-11-2012 | 06:31 PM
Default help with lipo!
Hello I just bought a rc8be and brushless. I bought a new venom pro charger, 3700 mah reedy 14.8v and 5500 mah reedy 14.8 volts. Both 4s. What amp should I charging 3700 and 5500? How long it should full charged? Is it auto cutoff when full charged? What I suppose to do with new 3700 mah? Break in? How?
Thanks!
Jamoranger is offline
Old 09-11-2012 | 07:03 PM
I usually don't break in lipos. To be safe you should charge the 3700mah at 3.7a and the 5500mah and 5.5a.
fung_kyle is offline
Old 09-11-2012 | 07:12 PM
But my venom pro charger only able charging 5.0 amp or less. Is it auto shut off when full charged?
Old 09-12-2012 | 05:04 AM
JustinThyme's Avatar
First you need to know what the charge rate is for the packs. Its normally listed on the spec sheet in a C rating. say the 3800 has a 2c charge rate.
3800mAh = 3.8 amps
3.8Ax2c=7.6 amps max charge rate.
Im not familiar with your charger so I cant tell you how it reacts.
As for breaking them in most manufacturers recommend fully charging and balancing then half discharge for the first 5 cycles.
JustinThyme is offline
