Like Tree11Likes
New LRP Flow Esc
Old 07-30-2015, 06:38 AM
  #1336
EDWARD2003's Avatar
Originally Posted by cplus
As above, would be v1.4 out the box.
If you're running boosted 13.5 would be better to update to one of the newer firmware. There is one for onroad mod motors and another for onroad stock motors such as yours that offers more tailored boost and turbo values. As well as the new brake profiles etc.
Which firmware should I use for 13.5 boosted? 5.4? 4.7?
EDWARD2003 is offline
Old 07-30-2015, 07:31 AM
  #1337
Mach10_shooter's Avatar
Trader Rating: 40 (100%+)
5.4! That's exactly what that firmware is for. Up to 60 on boost I believe.
Mach10_shooter is offline
Old 07-30-2015, 09:12 AM
  #1338
TChan's Avatar
Great! Thanks but as for the ESC not being able to setup, whats the issue? I cant seem to find any troubleshoot on the manual. The green set button doesn't even flash at all when i turn it on. The mode button just flashes blue and red. Any suggestions?
TChan is offline
Old 07-30-2015, 09:48 AM
  #1339
I found this but it says your green LED should be flashing fast also.
Old 07-30-2015, 09:56 AM
  #1340
TChan's Avatar
Exactly, so I'm not too sure what it means. I just bought a brand new LRP X20 13.5t, I hope its not defective! If my rotors arent turning will the engine not move at all when I turn it manually? Thanks!
TChan is offline
Old 07-30-2015, 11:31 AM
  #1341
Does anyone know what esc flashing for motor temp is in temp. I run an X20 13.5T and the temp reading of the for the motor temp reads 5 blink. What is that in temperature ?
Also, if using another brand of motor (Novak Vulcan) I can still get a reading from the LRP esc, but can I trust this reading ?
Shock Tower is offline
Old 07-30-2015, 11:53 AM
  #1342
chasingthepack's Avatar
have you reset your neutral point on the transmitter ?
chasingthepack is offline
Old 07-30-2015, 02:18 PM
  #1343
reg
Look at the pic that's a few threads up,it shows you at the Bottom 👍🏼
reg is offline
Old 07-30-2015, 08:56 PM
  #1344
TChan's Avatar
nope! well at least I dont think so. It's a brand new radio. Its the Sanwa M12, how can I reset the neutral point?
TChan is offline
Old 07-31-2015, 04:40 AM
  #1345
Bar
Default Firmware V5.4!
I have been running the latest V5.4 Firmware in 13.5 boosted class for some weeks, I have been struggling to get a smooth feeling through the powerband like I have when running my hobbywing, would anyone recommend using a different Firmware version to try?
Bar is offline
Old 07-31-2015, 07:38 AM
  #1346
Luke, what settings are you running on the speedo and what motor/timing?
scoyle is offline
Old 07-31-2015, 12:48 PM
  #1347
Sorry, didn't see that.
Does is apply to all brands of motors ?
Old 07-31-2015, 04:08 PM
  #1348
Bar
I'm running a Team Powers Actinium 13.5 -1 on timing
my settings on V5.4 are:-
3,1,0,3,0,10,6,0
Bar is offline
Old 08-02-2015, 09:30 PM
  #1349
Well has this happened to anyone else.
Racing Sunday speedo was working throw out the day, put the car down for the first final. The fan wasn't spinning no lights on, but the receiver and pt lights were on, got home and checked it. Working fine.
tiny tom is offline
Old 08-03-2015, 04:39 AM
  #1350
TryHard's Avatar
3,1,0,3,0,10,6,0
Try dropping the intial drive down (setting 4) lower. Give 1 (3%) a try.
Also try dropping the boost ramp, stock setting is equivalent to 500rpm/° OR 30,000 rpm boost range on the HW (assuming same total boost amount).
Failing all that... try the 4.7 software, as that gives boost and turbo control, and has some lower levels of initial drive too (which I've found even just 1% can make a big difference in how smooth the car is). I get the feeling 5.4 is aimed more at Blinky stock than boosted....
TryHard is offline
