New LRP Flow Esc
#1684
Recently acquired a new lrp flow works esc, upgraded to v5.4 firmware
Running a 24k motor that's relatively new. I've set it to max initial drive and my epa throttle /brake is at 135%
While doing full throttle runs inn the street, 1 in 5 or so runs on throttle, mid way, the car will cut out and then come back on if throttle is lifted slightly. Also under braking it may stutter
Reset calibration. Same thing. Turned epa for throttle to 100%, no issues. Tried it with another battery of the same brand and of a different brand while it was 135% epa and still the same result. Sensor cable is new
Any ideas
Update
Downgraded to v4.7 mod firmware. 135% epa seems okay with my testing, 6 seconds full throttle, off and again. Will test tomorrow with braking as it would stutter with the v5.4 /135% brake EPA
Any ideas
Update
#1685
Any ideas
Update
Any ideas
Update
#1686
Ok, hopefully lrps initial drive can make up for this
That's a real shame. My old hw v2.1 had no issues with this and being an esc that's over half the cost of the flow works
#1687
The only thing you are archiv with this setting is that you reach full throttle on the esc before you hit the max throttle on the radio. You can make a similar setting on the radio. like exponential setting to liniar and move the full throttle output to the desired point. In this case you get the same result.
#1688
I think you're referring to the arc level if it's a sanwa. Great. I'll experiment with this
#1690
issue with LRP flow work team esc
When I turn it on, the RED BLUE YELLOW lights blink continuously. (Not green light)
I pressed the set & mode button, no response.
Also I found that the esc got very hot.
What could be the issue here?
#1692
Try a new wire.
#1693
Any race at Tacoma that can help me download ans flash me ESC? I dont want to buy the usb adapter and run windows 10 so....
#1694
Setting up a used Flow Comp that I bought and I can't get any braking action. I am running 2S with a 10.5 motor. The car accelerates fine but has no brakes. I set my values to 0 before setup, the blue light is blinking after setup is complete, I assume in Blinky mode. I can put in enough brake trim to have the drag brake kick in when I let off the power, but the drag brake doesn't get gradually stronger with each click, it goes from no drag brake after 5 or 6 clicks trim to slamming on the brakes with an additional click of trim. Any ideas?
