cc sct bec?
#17
Well it arms and calibrates fine but now when push the throttle the green light will go solid then start flashing and beep it if I keep it held. But if I let go it goes back to yellow in neutral. Motor does not move.
#19
The red wire has been Removed. It has worked with the bec had a little wreck and car started acting up. Figired out wire from bec to reciever was not even getting a whole volt. Replaced the bec and its getting the programmed 6v. It worked then I cut esc off and put truck back together and it started doing what I mentioned last post.
