Problem with a hobbywing/novak ballistic setup >
Old 05-27-2012 | 02:37 PM
  #16
Also could be the BEC I had a similar issue when using a BEC on the novak speedo
Josh Pease is offline
Old 05-27-2012 | 03:47 PM
  #17
ps71's Avatar
Will try some differet things tomorrow, using it in a scte with 15t pinion.
Every setting on the radio is set to zero....
Thanks....
ps71 is offline
Old 05-29-2012 | 12:39 PM
  #18
Are you running the newest firmware for the ESC?
brew99 is offline
Old 05-29-2012 | 03:01 PM
  #19
ps71's Avatar
Pretty mutch tried everything i can think of all of your suggestions and it still have a lag.
However if i use a 3 cell battery it works fine and no lag at all......
So i think the esc dont like the 2cell together with the novak....
Well the tenshock is in the car now and that works great on 2 cell.....
Go figure
Thanks.......
ps71 is offline
Old 08-19-2012 | 09:42 AM
  #20
BloodClod's Avatar
Moderator
I just experienced the same thing with my Ballistic motor and Hobbywing setup.
I thought it was a faulty sensor board but I changed that and the same thing happens. It's got to be the motor/esc combo IMO because the problem disappears when I run any other motor.
Just posting this up in case anyone else experiences this so you know it isn't an isolated case.
If anyone has a solution to this please do share.
BloodClod is offline
