Droped a cell ???
Old 05-16-2012 | 09:19 PM
Tomac2's Avatar
Default Droped a cell ???
One of my 4s batterys has a cell that wont balance so the last few times Iv just charge it (with out balance) & hoped for the best. So far so good.
What could go wrong if I keep using it ???
Tomac2 is offline
Old 05-17-2012 | 06:14 PM
LanceBuku's Avatar
Does your charger have a readout for each cell while it's balance charging? If so what's the one cell that won't balance read?
LanceBuku is offline
Old 05-18-2012 | 03:50 AM
Tomac2's Avatar
C1, 2 & 3 usually ready 4.19v or 4.20v but C4 is anywhere inbetween 4.14v & 4.16v maximum
I dont bother to balance it anymore & it takes about 40 - 50 minutes at 10amps for a normal charge.
Iv only got two batterys & I carnt afford to buy more just yet.
Cheers
Tomac2 is offline
Old 05-18-2012 | 07:10 AM
Try balance charging at 1amp and let it go until it's done.
Lazer Guy is offline
Old 05-18-2012 | 07:12 PM
Tomac2's Avatar
I'll give it a shot
cheers
Tomac2 is offline
Old 05-18-2012 | 08:39 PM
LanceBuku's Avatar
Sounds like a bad cell. I'd recommend to balance charge it in a firesafe location. If the one cell won't get up to the other cells voltage is OK. What you don't want is to overcharge the other three cells and a balance charge won't let that happen.
If you don't balance charge than the cells that are good will be over charged and a fire is very possible, and you don't want that.
If the packs aren't that old I'd look to get it replaced.
How long does the charge take when you balance charge the pack?
I've had packs go to time out (aprox 90 minutes) on the balance charge because the bad cell just can get to 4.2 volts.
Old 05-18-2012 | 11:57 PM
Tomac2's Avatar
It times out at 120 minutes, Hence why I dont bother to balance it anymore.
I always charge it in a fire proof lipo bag too
Im more worryed about it catching on fire while its in the buggy
cheers
Tomac2 is offline
