sr 300 rx help
Old 05-10-2012 | 05:47 PM
vito's Avatar
Default sr 300 rx help
will it take a lipo rx pack 7.4 and will the on a off switch be fine with it too
vito is offline
Old 05-10-2012 | 05:51 PM
Lapper's Avatar
R/C Tech Elite Member
The SR300 will take a 7.4 LiPo pack but your servos won't unless you're using high voltage servos. The reason you see electric vehicles using a 7.4 without a BEC is because it's built into the speed controller only giving the receiver a voltage of @5/6 volts.
Lapper is offline
Old 05-10-2012 | 05:54 PM
vito's Avatar
the servos i like are
5585
5565
vito is offline
Old 05-10-2012 | 09:58 PM
Titian2010's Avatar
You are good to go. I think those are actually good budget HV servos for brand new. If they are new. I wanted a pair for back up in case my Savox blows. Good luck.
Titian2010 is offline
Old 05-11-2012 | 09:18 AM
vito's Avatar
will the on and off swithc be fine to
vito is offline
