Receiver Antenna Mod
I've searched around on the forums (this one and a few of the other more frequented ones online), and even had to resort to the wonderful vagueness of searching through the results from numerous Google searches. Can't find a thing on anyone doing this..
So I was wondering if anyone has been able to [successfully] replace their standard 'wired antenna' on their receiver, with one of the folding, molded plastic ones, that are more commonly seen on transmitters.
I believe the connection on the actual receiver board-itself, is called a U.FL Mini. I'm also fairly certain that replacement transmitter antenna's, available from the manufacturer, also use the same connector. Could these possibly be used?
Now I'm certainly not an RF Engineer, nor have I ever studied that area (apparently, LOL), so please don't chastise me or make me contact the good folks behind StopBullying.org. haha
I was just fiddling around with some of my cars today and that popped into my head.. So, I thought I'd ask!
lol
Thanks fellas! If anything, it's something that we can all learn and find out together!? Right?
lolThanks fellas! If anything, it's something that we can all learn and find out together!? Right?
See, I was thinking that!
However, the more I looked into it on Google and such, and some of the other more 'DIY-savvy' forums (i.e., HeliFreak... lol those dudes take it to a WHOLE DIFFERENT level! haha), I've heard of differences with Polarization, Diversity, Gain Patterns, etc..
Seems simply straight-forward, as you and I both seem to think, but maybe it's not..? lol
It would work I reckon, but don't think anyone would do this mod (on a land vehicle anyway) because:
- need to mod the radio box in such a way to accommodate the size of the moulded plactic antenna, and then find a way to 'fix' it in place (could press-fit the base through the hole drilled into the radio box I suppose)
- the likelihood of snapping it off in a crash, as opposed to a flexible plastic antenna tube which has plenty of give in it and is cheap as chips from a LHS
Marks for thinking outside the square though!
other then that why not
