Tekin Redline
Old 04-14-2012 | 06:09 PM
Default Tekin Redline
Does anyone know what the max rpm is on the Tekin Redline sensored 1/10 scale motors?
DanielD is offline
Old 04-15-2012 | 06:16 PM
Ttt
DanielD is offline
Old 04-15-2012 | 06:20 PM
mdwalsh's Avatar
which turn motors? each turn motor has a different kv rating. the kv rating is the rpm per volt.
Matt
mdwalsh is offline
Old 04-15-2012 | 06:26 PM
mdwalsh's Avatar
http://www.teamtekin.com/blmotors.html
MOTOR KV
Redline Sensored 2.5 11,900
Redline Sensored 3.5 10,800
Redline Sensored 4.5 9,300
Redline Sensored 5.5 7,700
Redline Sensored 6.5 6,700
Redline Sensored 7.5 6,100
Redline Sensored 8.5 5,300
Redline Sensored 9.5 4,900
Redline Sensored 10.5 4,500
Redline Sensored 13.5 3,500
Redline Sensored 17.5 2,500
Redline Sensored 21.5 2,100
Matt
mdwalsh is offline
Old 04-15-2012 | 07:01 PM
MOTOR KV
Matt
I know the kv rating....I asked what's the max rpm? Like on castles site it says the 5700kv motor is 100,000 rpm max and the 1/8 scale castle 2650kv is 60,000 rpm etc......
DanielD is offline
Old 04-15-2012 | 07:05 PM
mdwalsh's Avatar
id email tekin on that then.... i assume youre looking to run more volts than tekin recommends you run through their motors hence the reason youre wondering why....
...if i had to guess id guess its close to what castle recommends for their 1/10th scale motors at 100,000 rpms
Matt
mdwalsh is offline
Old 04-16-2012 | 10:35 AM
Randy_Pike's Avatar
Team Tekin
What are you trying to do?
Randy_Pike is offline
Old 04-16-2012 | 01:56 PM
Run a 3s lipo for high speed runs.Was told to use a 10.5t and it was slow as a snail.Being its 4500kv x11.1volts=49,950 rpms.And it got so hot after a 200ft. pass it nearly burnt off my fingerprints.
So i need to know what 1/10 scale motor can handle 3cells with the highest rpm.
DanielD is offline
Old 04-17-2012 | 01:36 PM
Randy_Pike's Avatar
Team Tekin
A 10.5 on 3s should have been ballistic. What esc setup did you try on that? And what car is it going into?
Old 04-17-2012 | 03:18 PM
bigjayjay1's Avatar
curious what gear also
bigjayjay1 is offline
Old 04-17-2012 | 03:25 PM
The Serpent S411 with RX8 esc.10.5 turn on 3s is not enough kv. Just tell me the max rpms on the 1/10 scale motors.I'm sitting here with 6 tekin speedo's and 7 motors and I need to know the max rpms
DanielD is offline
Old 04-17-2012 | 03:29 PM
1 to 1 ratio
DanielD is offline
Old 04-18-2012 | 09:31 AM
Randy_Pike's Avatar
Team Tekin
Well there's the issue right there. Why are you using the Rx8 in this application? The RS pro can also run 3s and run more timing in the setup.
Old 04-18-2012 | 10:21 AM
Using the RX8for more amps....So your telling me a rs pro can handle more and outproform the RX8?
What's so hard about answering the original question 14 posts ago.
What's the max rpms of the redline motors? Is it a secret?
DanielD is offline
Old 04-18-2012 | 02:41 PM
Randy_Pike's Avatar
Team Tekin
Daniel the RS pro has the ability to run sensored only mode which can provide boost and turbo timing.
You don't have to have an attitude. We rate our motors to 100,000 rpms as well.
However we only rate our 1/10 motors for up to 3s use. The RS pro has more fets than the Rx8. SO it too can easily handle the load.
For speed runs alone I may have suggested using one of our sensorless motors only because of their delta construction and larger rotor design the top speed can be found a bit easier.
