Glitching problem
Old 04-11-2012 | 11:52 AM
Default Glitching problem
I have a TLR 22 with a DX3R Pro, SR3100, Spektrum servo, Tekin RS esc and Redline 13.5 motor. When the car is at a stop, the car will barely go it is glitching so bad, but once it gets going, it's fine. I have tried changing motors, esc's, receivers, and batteries. I've re-calibrated the speedo and radio. I've tried two new sensor wires. What am I missing?
velotek1 is offline
Old 04-11-2012 | 12:10 PM
Do you have any of your wires braided together or coiled up (looks like a pig tail, curl Q)? This may be causing some electromagnetic interference or radio frequency interference. What battery are you running?
cody161 is offline
Old 04-11-2012 | 08:16 PM
Yeah, I've got my servo wire all bunched up. The thing is though, it worked with this exact setup perfectly for about 10 hours. I'm running a thunder power 25c sport pack. I was thinking maybe the radio and speedo didn't like each others settings?
velotek1 is offline
Old 04-11-2012 | 09:34 PM
A quick easy way to see if it is the servo wire causing any EFI/RFI would be to simply unplug it and then see if the esc works correctly.
cody161 is offline
Old 04-11-2012 | 10:16 PM
I just tried updating the ESC and unplugging the servo, neither made a difference. The only other thing I can think of is the radio itself. It's pretty new(about 12 hours on it) so any defect may just be showing itself. Hmmmm
velotek1 is offline
Old 04-12-2012 | 01:56 PM
trickedout's Avatar
are you running a sensored motor? If so, try a new sensor wire, a bad wire can cause the car to glitch and cog at low rpm's
trickedout is offline
