Virtual RC game set up thru a 3PKS controller >
Old 04-11-2012 | 12:59 AM
Default Virtual RC game set up thru a 3PKS controller
Anyone know how to set up the TX to work with the USB stick they supply to play the game online.
I got the futaba 3PKS TX.
Cruze is offline
Old 04-11-2012 | 01:09 AM
smith9turbo's Avatar
if your USB adaptor connection via DSC port.
at first you must set PWR-MODE of your 3PKS to PPM.
HRS or PCM will don't work.
then do joystick calibrate your 3PKS+usb adaptor on your windows.
see this page for guide => http://rc-usb.com/rcusb-dsc-ppm-en/
if your USB adaptor connect via receiver.
all PWR-MODE PPM, PCM, HRS can work. (if your usb adaptor can support all mode)
if not work, try PPM first.
see this page for guide => http://rc-usb.com/rcusb-rx2/
Note ...
9TURBO RCUSB-RX2 can support all mode PPM, PCM, HRS
work great with new 2.4G technology,
Sanwa MT4 + RX461 with RCUSB-RX2 can so controller sample rate on VRC PRO up to 190.
smith9turbo is offline
Old 04-11-2012 | 03:04 AM
It's the same as this one.
http://www.virtualrc.com/products/pr...cid=2&prid=235
Cruze is offline
Old 04-11-2012 | 03:24 AM
Set up a new model in your transmitter
Set your EPA's (travel) at 100%
Bind your Transmitter and receiver as you normally would
Connect usb dongle to pc
Connect throttle and steering cables between dongle and receiver
Computer will recognize the controller
Go into you Windows control panel and find the setup option for the game controller
Calibrate the controller using your transmitter
Start game and select the USB adapter
Good to go
Cheers
crusey_aus is offline
