-   -   Servo Help? (https://www.rctech.net/forum/radio-electronics/612528-servo-help.html)
Leadfinger2011 03-25-2012 12:44 PM
Servo Help?
Whats up Guys,
I's usually hunt this out with the seach function but I'm racing this evening and am really puzzled.
I have a Spektrum DX3R Pro running with the SR3100 Servo
I'm working with a brand new Savox 1258TG
I identified this on my last servo and replaced it with the TG thinking that was the issue but the issue is still there so for now i'll rule out servo. I re-bound the radio and receiver all good.
I've zero'd out everything on the radio and then set the travel to max 150 each direction. When i turn now i turn tight in one direction but nowhere near as tight the other. Do you guys have any idea? This thing was fine yesterday and this just popped out of nowhere? Any input is appreciated.
Kevin
crusey_aus 03-25-2012 01:34 PM
Did you centre the steering mechanically before attaching the servo horn ?
Your EPA's (travel) should be wound back from 150% to prevent damage to the servo
Cheers
Leadfinger2011 03-25-2012 07:48 PM
Cheers
Thanks Crusey!!! Yeah I should have put that in but thats where i started. I'm still very puzzled. Thanks for replying!!!
Kevin
AreCee 03-26-2012 06:24 AM
When you say you zeroed out the radio, did you use the reset function?
If you did then you will need to reset the parameters too. You do that by going into the parameter screen and cycle the steering and throttle through the full range and set it.
If you just zeroed out the travel ignore the above.
