4-pin connector
I'm looking to replace the Tamiya style 4-pin connector for my ROSS unit on my Ten-T and figured Deans Micro 4-pin would be good to use, but it's not. The pins are too close to get a good, solid connection.
So, my question is: Does anyone know of a good 4-pin connector to replace the Tamiya with?
I used 2 Deans mini 2-pin plugs. Use colored heat shrink tubing to tell which pair goes where. Works great if you wire the motor on one plug. this way you can remove the the motor if necessary. Also solder the motor wires directly to the motor terminals, this keeps them from slipping off due to engine vibration.
Hope this helps.
Hope this helps.
Thanks for the feedback!
That was actually something I was thinking of doing. I never considered wiring the motor serperatley and that actually sounds like it would be useful. May end up going that route.
