battery charging time???
i have a 4100mah c size battery for my glow plug igniter and a 2100mah c size battery. the charger im using is output 1.25v 170ma. how long should i charge the 4100mah battery? and how long for the 2100mah battery? the red light on the charger dont change colors or go out when its completed. thanks!
4100 mah would be 24 hours from dead at 170mah
2100 mah would be 12 hours from dead at 170mah Battery mah divided by the charge mah = X hours |
Originally Posted by vette66_00
(Post 10435751)
You would have to determine the time based on the amp draw over said 2-4 hours.
In theory lets say for simplicity reasons your ignitor pulled 170 mah an hour for 4 hours. You would have to replace that with 170 mah X 4, so 4 hours at 170mah back into the pack. Now these are just numbers and I have not figured in voltage drop that ninms and nicads lose just sitting and over time with storage loss. I don't have the figures for that. LOL To be honest I have a charger that for $45 bucks that will charge everything, lipo, liFe, Nicad, nihms, everything basically, and it came with all the plugs to charge those batteries including the ignitor plug. All you do is set the current and charge, it figures out when the battery is fully charged. Check it out here. http://www.hobbypartz.com/thac6smbachw.html Its the best investment I have made for my batteries to assure I dont have a failure. |
(Post 10437078)
| All times are GMT -7. It is currently 11:52 PM. |
