Looking for a solid and highly configurable ESC...
I have a mostly stock SC10RS right now. I'd like to update the ESC and use the stock motor for a while. It seems to be a pretty good motor to be honest.
Is it possible to add boost and or timing to a non-sensored motor via the ESC? Is there a good ESC that has plenty of configuration options that will run both a sensored and a non-sensored motor? I'll probably stick with a 2S battery but I'd like to be able to run as much motor as I might choose to some day.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
AFAIK, you can add "boost", but you can't mess with the timing unless it's a sensored motor. You can find a new MMP for around $100 shipped.
Thanks in advance.
Thanks in advance.
You CANNOT add boost to a sensorless motor. You can run Timing through a programmable esc tho. I recommend a Hobbywing 60a esc. Lots of tuning features, you can get the LED program box that is so simple to use without a computer. They run around $65 on www.Hobbypartz.com I beleive. I have had Castle, Tekin, Hobbywing...they are all good just if your wanting to save money with a quality esc Id go Hobbywing.
