Thunder Power TP-610c HELP!
Manual is posted online
http://thunderpowerrc.com/PDF/610C0-User-Manual.pdf
Been a while since I had one of those, but I want to say that when you start a charge it mentions checking the balancer (and whether or not it's connected) on the display(?)
I looked at the whole manual and it doesn't tell how to Balance charge it.
I just wanna make sure its balancing charge cause when I charged my 2s lipo one cell was 4.13 and 4.20 and it said it was fully charged
there is a setting for fast charge, 100% charge and I think like 90% charge. if you do the 100% charge, that is the balance charge. once you start it, it will look for the voltage and start to charge. if you hold down the green button it will switch over to the cell configuration and you can check voltages. the voltages will be different but as the pack charges to capacity the charger will decrease amperage and the cells will balance. My nano-tech pack i did the other day went to .01 or something really low. also, cheaper packs may not balance as well as more expensive packs with high discharge and capacity rates.
