EX5UR replacement trigger? >
Old 02-26-2012 | 07:04 PM
Default EX5UR replacement trigger?
Hi,
Can you buy a replacement adjustable trigger for the Ko EX5ur? It is annoying that have to reach forward to brake.
PUNKEE is offline
Old 02-26-2012 | 07:08 PM
reptile's Avatar
Originally Posted by PUNKEE
Hi,
Hi just slip a peice of silicone fule line hose that's used for nitro cars on the reverse brake side of the trigger this will take out most of the play.
reptile is offline
Old 02-26-2012 | 10:32 PM
I did that but it still feels like you are reaching for the brake. Thought about trying to heat it gently and bend it, but thought this may be a bad idea.
PUNKEE is offline
Old 02-27-2012 | 05:42 AM
klaymon's Avatar
I did that on mine. I drive with my finger tip and there were times I missed the brake because it's so far away. I heated up the brake side of the trigger and bent it in and slightly toward the back of the radio.
klaymon is offline
Old 02-27-2012 | 10:51 PM
Has it been ok since then?
PUNKEE is offline
Old 02-28-2012 | 06:00 AM
klaymon's Avatar
Never an issue.
klaymon is offline
