-   -   Can it be done? (https://www.rctech.net/forum/radio-electronics/602011-can-done.html)
mike22 02-22-2012 10:08 PM
Can it be done?
I have 2 lipo batt 2s wired in series with a connector I was wondering is it ok to charge them this was so I would be charging at 4s 14.8 volts instead of charging the individually at 7.4 2s, Tia
Tim3 02-23-2012 05:09 AM
Yes, if the the packs are exactly the same. I would make sure both packs are as close to same volts when you start charging them.
mike22 02-23-2012 07:39 AM
Tnx will try it out
Dave H 02-23-2012 07:46 AM
Recommend buying or fabricating a series balance harness if you hadn't already planned on it. And be diligent about hook up order.
btrukr 03-03-2012 05:38 AM
balance
Get yourself 2 blinky balancer's and balance each battery seperate, but charge together. Also be careful not to overdraw the powersupply if your charger is AC/DC. I blew one up charging a 6s at 5amp's. Neither my ICE or 989 care about it though, they don't even get hot.
