Do I need a BEC?
Old 02-18-2012 | 06:58 AM
Default Do I need a BEC?
Relatively new to electric side of things. Just put a Novak Timbuk2 Wraith Edition in my Wraith, along with a JR9100T servo for steering (370 oz/in @ 6V). I think the Novak has a 2A internal BEC, but came with a 5A External BEC. How do I know if I need to run the external BEC? Everything seems to be working fine as is. Running an SMC 8000 mAh 20C 7.4v LiPo.
sdtech58 is offline
Old 02-18-2012 | 07:44 AM
Steve737's Avatar
If everything is working like it should, you're good. Adding a BEC is simple enough, but it clutters up the inside.
Steve737 is offline
Old 02-18-2012 | 02:31 PM
King DORK's Avatar
I had a Novak Goat 3s system in my Losi Comp Crawler. It came with the BEC as well. The instructions stated to use the external BEC if using a 3s lipo. Check your manual and see if it's the same with your's. Added a mess to the wiring and a 2nd power switch.
King DORK is offline
