servo play
Old 02-17-2012 | 09:37 AM
elecRC23's Avatar
Default servo play
Hey guys, I just bought an associated b4.1 rtr, and I noticed that the servo has a lot of play. When it's off, i can move the servo about an inch further than it does when it is on. Does anybody know why this is or how i can fix it
elecRC23
elecRC23 is offline
Old 02-17-2012 | 09:57 AM
MarkA's Avatar
elecRC23
Are you asking about wobble, i.e. "play" or throw? If it's throw and you can move it an inch further off than on, the dual-rate adjustment on your radio is probably turned down and is limiting that.
MarkA is offline
Old 02-17-2012 | 10:05 AM
racer1812's Avatar
Super Moderator
While Mark is correct about checking your endpoint adjustment. What you describe sounds normal to me. Servos only move 60deg. each way with the radio, (120deg total). Moving them by hand you can get 180deg. plus full sweep.
racer1812 is offline
Old 02-17-2012 | 11:50 AM
elecRC23's Avatar
then how do you adjust you camber or toe when it is so wobbly?
elecRC23 is offline
Old 02-17-2012 | 12:24 PM
MarkA's Avatar
So you're referring to actual play in the front end then? The bolt on the spring for the servo saver is likely not tight enough. It's a common AE car issue. Crank it down. Also, make sure the screws described in step 3 here are tight as well. Same for all the ball studs throughout the front end.
MarkA is offline
Old 02-17-2012 | 12:49 PM
elecRC23's Avatar
ok, sorry but i'm really new to the whole buggy setup. I used to drive a sc truck so could you tell me how to get to that?
elecRC23 is offline
Old 02-17-2012 | 12:59 PM
MarkA's Avatar
The link I posted above goes to the entire instruction manual for your car. Give it time to load, it's a big file. Do it in reverse to get at the parts then put it back together following those steps.
It shouldn't be all that fundamentally unrecognizable compared to most SC trucks.
MarkA is offline
Old 02-17-2012 | 01:18 PM
elecRC23's Avatar
ok cool, thankyou so much for all of your help
elecRC23 is offline
